DominiqueS Posted November 6, 2015 Share Posted November 6, 2015 I do not seem to be able to reproduce this roof which has a different front and back The back is a regular low pitch gable roof while the front has 2 inverted shed roofs. I have just purchased Studio and dowloaded Architect trial to see if it would help but lack of knowledge could be the issue. As per one of the videos, I have added a wall in the garage and removed the roof from the space create. Change the wall "roof" parameter to high gable and I was able to create the 2 inverted front shed roofs. But I have no clue as to make a regular low pitch roof in the back. Can anyone guide me in the right direction. I have included some pictures. Hope you can see them Roof satellite view.tiff Pink House Original.plan Link to comment Share on other sites More sharing options...
solver Posted November 6, 2015 Share Posted November 6, 2015 Looks like you have some settings wrong on the back part of the house. Check walls to make sure nothing extra is checked. Set the pitch on the 2 outside walls -- you may need to break them where the shed roof stops. Set the end wall to full gable. See how the roof builds. You can post the plan file -- make sure it's closed in Home Designer, for better help. 1 Link to comment Share on other sites More sharing options...
DominiqueS Posted November 7, 2015 Author Share Posted November 7, 2015 The end wall was already full gable but removing the high gable on the side walls improved dramatically but changed the front left of the house to a gable. I am trying to post the picture. But it is much improved. Many thanks. Link to comment Share on other sites More sharing options...
DominiqueS Posted November 7, 2015 Author Share Posted November 7, 2015 https://www.homedesignersoftware.com/support/article/KB-00492/building-a-clerestory-roof.html gave me the solution. I needed to make the left room ceiling lower to separate it from the right side. Link to comment Share on other sites More sharing options...
