warrenwest Posted October 13, 2015 Share Posted October 13, 2015 Hi, So I had to download a box down light ( for ceiling ) from 3D warehouse as there is nothing similar in HDP library but obviously there is no imported light data. I have tried to use the 'add lights/adjust lights' menu to try to recreate a spot light that shines down to no avail. Any idea how to accomplish this? Link to comment Share on other sites More sharing options...
warrenwest Posted October 13, 2015 Author Share Posted October 13, 2015 OK never mind I just dropped a recessed light over the light fixture and adjusted its height to coincide with the light from the box light. Problem solved. Link to comment Share on other sites More sharing options...
katalyst777 Posted October 14, 2015 Share Posted October 14, 2015 The Premier version lets you actually add lights to the symbol itself, so you can also try asking over in the ChiefTalk Symbols & Content forum to see if someone can import the symbol and actually add the light for you and send you an editable plan with that symbol in it. 2 Link to comment Share on other sites More sharing options...
