Sign in to follow this
DavisR
NEWBIE: Printing Plans
Hi!  I'm a newbie and have a couple of questions.  I have the HDSuite 2016 software and will probably need to upgrade.  If I upgrade to Home Designer Pro, will I be able to setup the plan and interior/exterior elevations for oversized printing?  If not, can I export individual dxf files - or perhaps even print to a PDF and then size as required?  I simply cannot afford the Chief Architect versions just yet.
Thanks so much for your time!
Yes you can Save to PDF and then Print to a max of 200% to get full sized 24x36 ( ie a 12x18 PDF @ 200%)  plans if needed.
You cant do elevations or sections in Suite though so Pro is probably needed. Not sure if HDA would suit or not as I am not sure of it's capabilities
Thanks Mick!  Yep... it sounds like I'll be upgrading to the Pro version.  At least I get a credit for the $'s for the current package.
