blackbeard Posted August 23, 2015 Share Posted August 23, 2015 Using HDA 2015; Build 16.4.1; intel based pc. From the Library Browser, selected Architectural, Doors & Doorways, Wrapped Openings, Ellipse (Trim) and places on an interior wall, (Interior 4). Opening the camera, the doorway is an arch as it should be. Opened the properties for the doorway, changed the width from 42" to 72" and the height from 80" to 84". Again, opening the camera but now the wrapped opening is a standard square door opening. What happened to the arch? Using the doorway properties dialog box, arch, puts a true semi circle arch and not an ellipse. The prior version never did this. Opening drawings completed for HDA 2015 are not effected when viewing by camera. Only when a new wrapped opening is used. Any suggestions? KevinK Link to comment Share on other sites More sharing options...
Elovia Posted August 23, 2015 Share Posted August 23, 2015 I, too, wasn't able to reproduce the reported behavior in HD Pro 2015. However, HD Archtectural 2015 has an Arch tab in the doorway specification dialog (as shown in the 2nd image in the original post). You should be able to use the functionality on that tab to restore the arched opening - or apply other arch shapes as desired. Link to comment Share on other sites More sharing options...
blackbeard Posted August 24, 2015 Author Share Posted August 24, 2015 I did provide the product and version, first sentence. ( Home Designer Architect) HDA, (version) 2015 along with the build value. As to using the door dialog box, arch, that setting puts a true semi-circle and not an ellipse. DJP, do you have any suggestions? kevink Link to comment Share on other sites More sharing options...
Kbird1 Posted August 24, 2015 Share Posted August 24, 2015 Yes please add your info to your Sig. , see mine for a how to , there are 30 or more versions supported here, all with different capabilities. Thx. Does HDA not allow you to change the Arch type in the DBX'S drop down menu? Perhaps that is only Pro? Link to comment Share on other sites More sharing options...
blackbeard Posted August 24, 2015 Author Share Posted August 24, 2015 Finding a bug wouldn't be the first time for me. I'll report it to support. kevink Link to comment Share on other sites More sharing options...
