Sign in to follow this
solver
Mulling Windows
Placing windows with the default separation of 2" results in the 2 on the left. You can override this by doing a copy and paste of a window and pasting close to the copied window. Results on the right.
I've changed the default separation to 3-1/2" as that's how I trim them out if they are separate and not mulled.
How would you do things, if the window "units/elements" were actually mulled? I have a large fixed/picture window above an awning. I already did what I think you are suggesting by adjusting the top sash of one and the bottom of the other, but is there actually a way to make them as a single mulled unit that can be moved as a single object?
No mulling of windows in the Home Designer products.
You can also change the Default window Separation , I usually have it at 1/2 "
