user-bob Posted June 28, 2015 Share Posted June 28, 2015 I have (3)dormers even with front wall on the second floor (10' pitch roof) software put a roof in front of the dormers. how do i remove the roof in front of dormers? software home designer architecture 2016 trial cbisringhausen@att.net Link to comment Share on other sites More sharing options...
Jo_Ann Posted June 28, 2015 Share Posted June 28, 2015 You manually build them as 'rooms' on the 2nd floor (separated from the main floor by invisible walls, and with a normal ceiling height). Not auto dormers. The roof will then build around them, but not in front of them. Link to comment Share on other sites More sharing options...
Kbird1 Posted June 28, 2015 Share Posted June 28, 2015 If they are true Dormers , Jo_Ann's method works , (see Pic) , if they are really floating Dormers ( no walls in room) then Jo will have to advise what HDA is capable of , or what the workaround is since she has HDA. Link to comment Share on other sites More sharing options...
user-bob Posted July 6, 2015 Author Share Posted July 6, 2015 I BUILT MANUAL DORMERS TWO SAME SIZE CENTER ONE LARGER ON FRONT WALL. WHEN THEY BUILT THEY ARE GABLE ROOFS NOT DORMERS. I'M NEW TO THIS PROGRAM Link to comment Share on other sites More sharing options...
Kbird1 Posted July 6, 2015 Share Posted July 6, 2015 Bob , I think you caps lock key is on ? not sure what the issue is though ? you don't want gable roofs? , then change the Wall>Roof directives on the Dormers , same as any other wall to built hip or Shed. might be time to check the manual or the KnowledgeBase here http://www.homedesignersoftware.com/support/database.html specifically : http://www.homedesignersoftware.com/support/article/KB-00359/52/Home-Designer/Roofs/Automatically-Building-the-Basic-Roof-Styles.html Link to comment Share on other sites More sharing options...
