Sign in to follow this
English
Site Plan
I have done many site plans before where I have taken a survey and imported it into an ACAD window and then added my dimensions to the lot lines.  Having not done this with this program is there any information that you can give me that may help?  I'm not sure what format the survey is in.  Would a simple copy and paste work?
Thanks
Alan
if you can't find out the data type , do you know the file type? .csv? .gpx ,dxf ? etc?,
http://www.chiefarchitect.com/support/article/KB-01078/150/Chief-Architect/Terrain/Using-Real-World-Elevation-Data-to-Create-a-Terrain.html
dxf/dwg
http://www.chiefarchitect.com/support/article/KB-00719/150/Chief-Architect/Terrain/Importing-Terrain-Elevation-Data-from-a-dxf-or-dwg-File.html
with .csv
you would just have to try it with different settings I think until it came in correctly ( use a new blank plan to test), if the file contains lots of Elevation point data it will slow Pro down in 3D views ,some tips
https://chieftalk.chiefarchitect.com/index.php?/topic/1113-importing-csv-terrain-data/
if you don't need all the topo data and if you have a printed copy , it maybe just as easy to use this KB article.
http://www.homedesignersoftware.com/support/article/KB-00850/72/Home-Designer/Terrain/Drawing-a-Plot-Plan.html
or
http://www.homedesignersoftware.com/support/article/KB-00576/
Mick
I just copied the data over from the paper copy.  Used the tutorial which worked a treat -- except for the text size but that got fixed by tech support (see my other post).
Thanks
Alan
