Sign in to follow this
Perrys6
Wall Niche
I need to recess two wall niches one on either side of a fireplace in a wall. The wall has a stack stone material added to the surface. Can anyone tell me how I can add the niches recessed into the wall. I'd like the niches to be 12" x 12" x 8" deep, with the same stack stone material inside of them.
Thank you in advance for your help.
Perrys6
Try a window pass thru and use a cabinet soffit to put a back inside it , you can turn off the casing etc if needed, this works for shower niches too.
Edit :  found an old Niche practice plan you should be able to open and have a look.
Wall Niches Basic House.plan
Kbird, thank you for your help. That was perfect. I appreciate your help.
Kbird1, thank you for the snapshot to view.  I created a window with fixed glass, deleted the frame, lintel, etc..then added tile material to it to and made it a niche in my shower. Chief Architect Premier X7 version.
The Chief Architect forum is ChiefTalk.
