Joining Windows
KnarrlyViking
Go to solution Solved by Kbird1,
I have HD Pro 2014.  Trying to create a set of joined windows for our future house living room.  3 double hung windows side-by-side with 3 transom windows side-by-side above them.  The window manufacture will combine all 6 windows with no mulling or mulling between.  Right now, I'd like no mulling, but bumping the windows together produces a 2" separation between the windows (for a 2x stud that I don't want).  Is there a solution for joining windows without the gaps?
Thanks.
  • Solution
you need to set the Window separation , it's default is 2" , it's in    Defaults>Window >General Tab  (at the bottom) .
it maybe useful to also check the Box while in there for     Defaults>Plan>Ignore Casing for Opening Resize.  ( at top in general section)
Regarding the windows, depending on the size, you may want to look into the wind loading on that side of the house. Windows just attached at the frames with no structural support can bow in with strong winds. Might depend on what brand you are thinking to use.
