Landscaping mounds
DaveRegis
I've got a flat lot with a landscape perimeter defined, and I'm trying to create landscaping mounds.   These need to be irregular-shaped and smoothly transition from the base terrain and raise to specified elevation.
Prior to HD-2027, there was a Terrain Modified menu selection that would let you define raised or lowered areas, but I don't see that anymore.   Is there a new way of doing this?
You're right it does create an elevation spline. Elevation data needs to have contrasting information. if there is only one piece of elevation data it will always be flat. You'll need 2 pieces. If the majority of the lot is flat and you're jest adding a couple of mounds I would create a flat region that bends around the mounds at a lower elevation than that specified in the mounds.
