andrewcali Posted May 6, 2015 Share Posted May 6, 2015 Has anyone found a way to make a true circular counter top, drive way, flower bed etc...The arch tool ( on custom counter tops, flower beds, driveways etc..) bows out only..will not let you arch inward. How can I make an IN-WARD arch? (an arch that bows in- to mach the other side bowing out) To create a true circular counter top like the one in this photo................ Or driveway....etc...I am aware of this tutorial. It does not solve the issue.http://www.homedesignersoftware.com/support/article/KB-00983/ Link to comment Share on other sites More sharing options...
Solution andrewcali Posted May 6, 2015 Author Solution Share Posted May 6, 2015 Never mind I figured it out!! this tutorial helpshttp://www.homedesignersoftware.com/support/article/KB-00774/ Link to comment Share on other sites More sharing options...
Kbird1 Posted May 6, 2015 Share Posted May 6, 2015 What the 1st Tut. doesn't make clear is that the RESHAPE ARC HANDLE , a triangle, ( seen in image halfway down) is very important for altering curves and making full circles or even convex (inward curves) easily by just pulling in or out, best to just try it and you'll see what I mean. http://www.homedesignersoftware.com/support/article/KB-00983/ Link to comment Share on other sites More sharing options...
katalyst777 Posted May 6, 2015 Share Posted May 6, 2015 As a side note, I think only the Premier version allows you to create actual bowed in cabinets like what are shown in your image, but you can probably fake the look with a bunch of custom countertops stacked on top of one another. Link to comment Share on other sites More sharing options...
