RicBrown Posted yesterday at 02:17 AM Share Posted yesterday at 02:17 AM How to draw deck stairs so the first step is even with the deck, 1 Link to comment Share on other sites More sharing options...
y-g-m-n Posted yesterday at 06:31 AM Share Posted yesterday at 06:31 AM the top step is one down from top floor/landing review all the stair options screen gives you. Link to comment Share on other sites More sharing options...
RicBrown Posted yesterday at 09:42 AM Author Share Posted yesterday at 09:42 AM When building decks we always start the top step even with the deck surface so what I'm asking is how can you raise the stairs so its even at the top of the deck as shown in the picture Link to comment Share on other sites More sharing options...
y-g-m-n Posted 7 hours ago Share Posted 7 hours ago might not be able to in the HD series. Unless try making a landing at the top the sane size as your top step and then the stairs can come off of it... might look right. HD just not setup to build the extra top tread when the top level will suffice... I hate to say it but might be easier in long run to change the way you build them and save some $ on the cost of that last tread Link to comment Share on other sites More sharing options...
Rookie65 Posted 23 minutes ago Share Posted 23 minutes ago Open your stair specification drop box. Under the "section heights" area, check "top tread" only and set it to "lock top". Then you can adjust the materials, etc. as needed. You should update your signature with the program version and type so everyone knows what you're working with Link to comment Share on other sites More sharing options...
