y-g-m-n Posted June 28, 2025 Share Posted June 28, 2025 I have some issues with your false advertising which I think you can easily fix. EXAMPLE FEATURED catalog for BLUMSAFE - what a great idea let me down load and check it out. Says compatible with HD PRO so I cam good to go. WRONG.. Does not work as for CA latest only. Can you either put in proper download file for HD products or correct where you says it works with HD.. Have others like that too. BonusMEPToggleSwitches yeah more switches - WRONG unless you have CA. Link to comment Share on other sites More sharing options...
DerekPedersen Posted June 30, 2025 Share Posted June 30, 2025 Hello and thank you for your feedback. The Blumsafe catalog was released after the release of our newest version (Chief Architect X17). When we release the Home Designer equivalent of X17 (Home Designer 2026), you will then see availability for Home Designer. Catalogs that are released are available for the current version and future versions. They are not backward compatible. I will pass your feedback on to our catalog team to see if we can fix the issue you have discovered. Kind regards, Derek Chief Architect Software 1 Link to comment Share on other sites More sharing options...
y-g-m-n Posted July 1, 2025 Author Share Posted July 1, 2025 Thats fine and dandy just fix the text to say good for X17 only. When the new HD 2026 comes out then add that to text and let the world know - kinda like advertising... thanks for reading 1 Link to comment Share on other sites More sharing options...
