Nimbleslick Posted May 29, 2025 Share Posted May 29, 2025 Is it possible to create a sloped retaining wall that starts at 12ft at one end and terminates at 1ft at the other? You know, like a triangle shaped wall? Thanks! Link to comment Share on other sites More sharing options...
CarrieS Posted June 19, 2025 Share Posted June 19, 2025 Retaining walls typically slope with the terrain around them. This article's main image shows an example of this: https://www.homedesignersoftware.com/support/article/KB-00990/creating-a-retaining-wall.html If you need to make the wall slope differently than the terrain, you could use the wall polyline to change the shape of the retaining wall if you have Home Designer Pro, like we show in this article:https://www.homedesignersoftware.com/support/article/KB-01809/creating-a-stepped-foundation.html Carrie Link to comment Share on other sites More sharing options...
