Garage
English
I have a couple of questions in adding a garage.
I added a slab on grade garage structure to the side of the house.  The grade is 36" below the first floor level.  I entered -36" as the floor height in the structure window but in 3D view the siding on the side wall of the house in the area of the garage has now extended down to the garage floor.  How can I stop that as the existing structure should not be affected by the garage?
The second questions is why are the garage walls appearing on my second floor plan?
Thanks
Alan
For some reason the slab is not showing up even though I set it at 4" thick.  If you look at the siding wall of the house it has been lowered down to meet the (invisible) slab because I set the garage floor to be -24".  This shouldn't happen.  I'll try and post a plan later.
Alan
