AskArmen Posted September 4, 2024 Share Posted September 4, 2024 Hello - I'm a relatively new user, any tips would be appreciated. Specifically I am trying to achieve the large roof slope effect on the left side of the house (behind the directTV antenna). How do I configure the roof definition (or the exterior wall definition) to achieve this? Its a single room underneath. Also the highest roof area with the 4 windows horizontally? Do I need to create another floor / attic? I am running Home Designer Pro 2025, version 26.2.0.52 macOS Thanks very much - and yes I've already painted the house to improve the color scheme ;) Link to comment Share on other sites More sharing options...
Angie15 Posted October 9, 2024 Share Posted October 9, 2024 Select the front GF wall, change it to a hip wall. select the left side bearing wall and change it to a high shed wall. Tell first floor to ignore roof (or in chiefs case, 2nd floor.) The back wall roof pitch will determine the roof and attic walls for the 4 horizontal windows, but my bet is that you'll have to build this manually, its beyond HD Pro. Its even beyond Premier. Its a manual build. Link to comment Share on other sites More sharing options...
