Baandit Posted September 1, 2024 Share Posted September 1, 2024 There are no items in the texture library Link to comment Share on other sites More sharing options...
Baandit Posted September 1, 2024 Author Share Posted September 1, 2024 BTW, I am on Home Architect Pro 2025 Link to comment Share on other sites More sharing options...
DaveRegis Posted September 10, 2024 Share Posted September 10, 2024 Did you upgrade from the 2024 version... or a lower tier? If so, check the equivalent folders for those products for your textures. For example, if you'd upgraded from 2024, look in ...\Documents\Home Designer Pro 2024\Textures If you can find them, just copy them over to the folder for the 2025 version Link to comment Share on other sites More sharing options...
Baandit Posted September 10, 2024 Author Share Posted September 10, 2024 Thanks, I appreciate you helping. Actually I installed Pro '25 so I haven't upgraded. However, the tech help desk suggested I load '24 so that I get all the libraries, then open '25. It seems to be working... Link to comment Share on other sites More sharing options...
KittyKatz Posted May 24 Share Posted May 24 Hi Baandit, I am having the same problem as you posted in September 2024 about your textures disappearing. I'm using Pro '25. I don't see anywhere that I can download version2024. Link to comment Share on other sites More sharing options...
Rookie65 Posted May 24 Share Posted May 24 When you see that error, it's likely that the material has been discontinued. Best to replace it with something that is in your current library. Link to comment Share on other sites More sharing options...
