I seem to have lost my texture library. Is there a way I can download it again?
Baandit
  • 2 weeks later...
Did you upgrade from the 2024 version... or a lower tier?   If so, check the equivalent folders for those products for your textures.
For example, if you'd upgraded from 2024, look in ...\Documents\Home Designer Pro 2024\Textures
If you can find them, just copy them over to the folder for the 2025 version
Thanks, I appreciate you helping. Actually I installed Pro '25 so I haven't upgraded. However, the tech help desk suggested I load '24 so that I get all the libraries, then open '25. It seems to be working...
