How do I add backsplash behind range?
MartaLKR
If you're trying to match a backsplash provided by an adjacent base or wall cabinet, (and even if you aren't) then consider placing a custom sized soffit against the wall behind the range.  Set the soffit thickness and texture to match the cabinet counter backsplash or as desired.
Good luck. :)
I thought Pro 2015 had the Custom Backsplash tool?
The old trick is to just put a cabinet in the same width as the range and then reduce it's depth to say 1/2" and you will still get the backsplash as long as you keep the Countertop ,reduce overhang to 0" but keep it. you can remove the cabinet face if you want but it's not usually needed.
