jalun459 Posted February 5, 2023 Share Posted February 5, 2023 Hi, I am trying to create a window opening in a thick stone will where the opening is wider in the inside than the outside (see attached simple drawing). I am using Home designer architectural 2023. Would appreciate any advice on how to do that. Link to comment Share on other sites More sharing options...
jalun459 Posted February 6, 2023 Author Share Posted February 6, 2023 Thanks, started there but didnt find anything on this specific topic. Any help much appriciated! Link to comment Share on other sites More sharing options...
Garybills Posted February 6, 2023 Share Posted February 6, 2023 I did one in Home Designer Pro making a double wall, putting a window in the outer wall and a larger pass through in the inner. The angled sides I used cad box converted to a slab and the hardest was the top and bottom angles I used a backsplash. Someone else may have an easier and better way but this gets you there. Link to comment Share on other sites More sharing options...
