jmyers Posted January 8, 2023 Share Posted January 8, 2023 I am working in HD Pro 2021 and no longer have roof overhang dimensions when I select the roof plane. I need to adjust my overhang to exactly 12 inches and the length of the overhang is no longer displaying. It once did, but I must have changed a setting unknowingly. Can someone point me in the right direction. Thanks! Link to comment Share on other sites More sharing options...
Solution Garybills Posted January 8, 2023 Solution Share Posted January 8, 2023 Check your temporary dimensions tool to make sure it’s turned on. Link to comment Share on other sites More sharing options...
Garybills Posted January 8, 2023 Share Posted January 8, 2023 2 minutes ago, Garybills said: Check your temporary dimensions tool to make sure it’s turned on. Link to comment Share on other sites More sharing options...
jmyers Posted January 8, 2023 Author Share Posted January 8, 2023 8 minutes ago, Garybills said: Check your temporary dimensions tool to make sure it’s turned on. Gary -- That was the fix. Thank you! 1 Link to comment Share on other sites More sharing options...
