Numbers missing in dimension line
LeftRightDesign
Go to solution Solved by LeftRightDesign,
Working in HDPro 2023.  Dimensioning an inset cabinet w/ 1-1/4" frame.  The dimension line shows only some of the frame dimensions.  When you select the dimension line, you can see the dot you use to move the number around, but there are no actual numbers displayed.  Been having this problem w/ all of the cabinets, altho it seems random which dimensions show up and which don't.
Is this a bug or am I doing something wrong?
