Windows in Basement Wall
Nirvana
I am using Home Designer Suite 2015.  I have completed my main floor design and I'm starting to work on the basement.  I have been successful in creating window wells and putting windows on basement walls.  However, when I start putting up 4" interior walls over the basement/foundation walls, my windows get covered up.  Is there something I can do with the window attributes to correct this problem?
See attached image.
Thanks in advance.
I sort of stumbled onto that solution.  I did put another window on the inside wall which appeared to do what I wanted.  I also tried putting the window on the inside wall and then creating an opening on the outside wall, but that didn't work.  I'll try the opposite.  Otherwise, I'll just double up the windows.  That's unfortunate that I would need Home Designer Pro to make a proper fix.
Thanks for your help.
This issue came up last year but I am unsure if in Suite you can modify/Copy Wall definitions ? , if not the Window and Pass through on the
inside is the only way ( use a Doorway for a Door)
but here are the threads from last year, on altering the Wall definition way....
https://hometalk.chiefarchitect.com/index.php?/topic/430-basement-windows/#entry2310
https://hometalk.chiefarchitect.com/index.php?/topic/419-framing-not-showing-in-self-defined-wall/#entry2311
