Create walls at the desired angle.
RafaelM
Hello, I am a new user of Home Designer Pro 2022. I would like to learn to draw walls where I can modify the angle every 1º (one degree) to be able to easily adapt them manually on the image of the plane that I draw and I do not have to adjust when editing the angle. Thanks
In the Wall specification dialog there is an input box for "angle". By default the software is designed to move objects in 7 degree increments but that can be overridden by using the control key (CTRL) or by turning off "Angle Snaps" or additionally by using the "Allowed Angles" input box in the "General Plan Defaults" dialog, it just depends upon what you wish to do.
