tspear Posted November 13, 2021 Share Posted November 13, 2021 Hello, Using Home Designer Suite 2021. I am not sure I did the terrain correctly, and as a result I am having problems connecting stairs from a patio on the first floor to a patio on a walkout basement. Key points: The home site is a flat area on the crest of a steep hill The house will be set back about six feet from the edge of the hill Retaining walls will extend from the house to cut out the hill, allowing for a basement walkout onto a lower level patio. Any pointers would be appreciated. single story with basement v0.plan Link to comment Share on other sites More sharing options...
tspear Posted November 13, 2021 Author Share Posted November 13, 2021 The stairs do not "connect" to the from the walkout basement patio to the first floor patio. Tim Link to comment Share on other sites More sharing options...
tspear Posted November 13, 2021 Author Share Posted November 13, 2021 The top of the stairs fail to connect to the 1st floor. If you right click on the stairs and select auto connection you get an error message. I eventually figured the issue out. Yes, I had the terrain defined incorrectly. I used a terrain region and set it as the floor for the lower patio. After watching a few videos on pools, I eventually figured out I need to instead use the terrain feature, and set the height to the -96; e.g. the floor of the basement patio. Now just to figure out why it is complaining about my knee wall and why my retaining walls do not extend downward. Link to comment Share on other sites More sharing options...
