2 independent house on the same lot
Clognose
Hello, I'm using HDpro2021, I'm doing a project, of 2 houses on the same lot. the ground level in the parking is 2' lower than the main house. also i only have one story for the shed, the house have 3. when i add the additional floors on the main, the shed got them too. anybody knows why or is there a video i can watch to make them independent? Thanks
You make them "independent" manually by manually setting the floors of the secondary structure 2' lower manually, per floor. The main structure then follows preset defaults and in the secondary structure you set its floor and ceiling heights manually 2' lower or higher as the case may be in your case. In such a case it is YOU who does the manual settings for the exceptional, secondary structure.
Thanks I was getting lost, ill post the results
Just now, solver said:
Please post questions in Q&A. Tips & Techniques is where you share your tips and techniques.
Please delete this thread via Moderator Actions near the top of the page.
No prob, I didn't know if it was a technique issue?
