hudder Posted January 21, 2015 Share Posted January 21, 2015 Hi... I am using Home Designer Pro 2015. Window labels are in the format 6050TC for a 6'0" x 5'0" triple casement window. Does anyone know how I can change the label to be in inches as opposed to feet and inches, so instead of 6050TC, I would be showing 7260TC? Thanks Link to comment Share on other sites More sharing options...
Kbird1 Posted January 21, 2015 Share Posted January 21, 2015 Turn off Auto label and specify your own on the windows label tab should work , you can make it anything you want, though the feet inches method is the industry standard. you might be able to do it using text styles options somewhere but I haven't dug that deep.... M Link to comment Share on other sites More sharing options...
hudder Posted January 21, 2015 Author Share Posted January 21, 2015 Ok Thanks...I was hoping there was a way to change it globally so I wouldn't have to go into each window and specify the label Link to comment Share on other sites More sharing options...
Kbird1 Posted January 21, 2015 Share Posted January 21, 2015 Turn off Auto label and specify your own on the windows label tab should work , you can make it anything you want, though the feet inches method is the industry standard. you might be able to do it using text styles options somewhere but I haven't dug that deep.... M did you look into text styles in Plan Defaults, ? not sure if possible or not there but in Plan Default>Windows>Label you have global Plan options too, but no idea on auto size labelling I don't have access to Pro to look into it for you today.... Link to comment Share on other sites More sharing options...
