Ginger Posted May 27, 2014 Share Posted May 27, 2014 Guys is anyone running HD Architect with a Microsoft Surface Pro ? Link to comment Share on other sites More sharing options...
Kbird1 Posted May 27, 2014 Share Posted May 27, 2014 There is one or two guys on Chieftalk using X6 on the Pro so i'd think it was ok , but you could try a search over there as I haven't seen it mentioned here before. Link to comment Share on other sites More sharing options...
katalyst777 Posted May 27, 2014 Share Posted May 27, 2014 There were many threads on the old HomeTalk about these. Their video doesn't meet the minimum system requirements and they aren't supported. If you only care about the 2D floor plan, you might be okay, but the 3D is one of the main advantages of using this software. 2 Link to comment Share on other sites More sharing options...
Kbird1 Posted May 27, 2014 Share Posted May 27, 2014 there are a number of guys on Cheiftalk talking about the Pro (1+2, 3 is now out as well) , might be worth messaging them or starting a thread over there.... https://forums.chiefarchitect.com/index.php?/topic/702-x6-imports-room-planner-files/?hl=laptop#entry5328 Of course the screen small but an ext. monitor in the office would help with that issue M. Link to comment Share on other sites More sharing options...
Kbird1 Posted May 30, 2014 Share Posted May 30, 2014 Not sure about older versions but 2015 does support HD integrated graphics ,see system reqs. here http://www.homedesignersoftware.com/products/system-requirements.html Link to comment Share on other sites More sharing options...
Stefzman Posted April 2, 2016 Share Posted April 2, 2016 Guys is anyone running HD Architect with a Microsoft Surface Pro ? I have borrowed a friend's device and am trialing this weekend. It is a MS Surface Pro 4 model, I7 processor, 8 G RAM, 64 bit processor. I've temporarily installed CA v17 for a test drive. Overall, it's running well. The surface introduces the pen as a new pointing device. That works with CA. Surface also has a touch pad for regular mouse actions. The only issue that I've detected is that, while the touchpad mouse will work with the commands on the CA ribbon, it disappears when I move it to the drawing area. I changed the color of the mouse and other attributes to see if there was any change; simply, no. I connected an external mouse. Same result. I have not checked the knowledgebase or done any internet searches to see anyone else has had the same issue. The workaround is to utilize a combination of the pen and the touchpad. Would be curious is anyone else is having any issues. Thanks. I Link to comment Share on other sites More sharing options...
katalyst777 Posted April 11, 2016 Share Posted April 11, 2016 Stefzman - This thread was originally started back in May of 2014, the original question was answered.A lot has changed since then, and your formatting makes it look like you're just quoting Ginger, rather than asked a new question of your own.You'll probably have better results starting a new thread. Link to comment Share on other sites More sharing options...
