jose_pinto73 Posted May 11, 2020 Share Posted May 11, 2020 Hello, I need help in building a window in aluminum in my plan, see attached picture for reference. I'm using Home Designer Architectural 2021 on macOS Catalina. Regards, Jose Pinto Home Designer Architectural 2021 macOS Catalina Link to comment Share on other sites More sharing options...
DavidJPotter Posted May 11, 2020 Share Posted May 11, 2020 The window shown appears to be a wooden window (you said aluminum), it is easy to change materials via the "Materials Tab" of the "Window Specification Dialog". The window in the photo appears to be a sliding window but I suppose it could be a casement. The interior shutters can be manually placed as symbols from the "Library Browser"(Core Materials - Architectural - Millwork - Exterior Shutters). The "Sash" dimensions can be edited by way of the "Sash" tab of "Window Specification Dialog". and the "Window Type" can also be edited by way of the Drop-Down menu by the name "Window Type" on the "General Tab of the "Window Specification Dialog"., take a look please. DJP Link to comment Share on other sites More sharing options...
jose_pinto73 Posted May 11, 2020 Author Share Posted May 11, 2020 David. Thanks for your reply. I wll try that. Link to comment Share on other sites More sharing options...
