rfcomm2k Posted November 21, 2014 Share Posted November 21, 2014 In the attached plan I have tried to change the flooring in the bathroom to ceramic tile. In the room DBX it is specified to be tile, but in the camera perspective view it still shows a wood floor. I checked default settings and see nothing there that calls to me. What is causing this? Link to comment Share on other sites More sharing options...
Solution Elovia Posted November 21, 2014 Solution Share Posted November 21, 2014 Unfortunately, the plan doesn't seem to be attached. However, take a look at the room specification dialog and ensure that your flooring has a specified thickness. If your floor has a thickness of zero inches, then this may be your problem. Hope this helps. Link to comment Share on other sites More sharing options...
rfcomm2k Posted November 21, 2014 Author Share Posted November 21, 2014 You nailed it Elovia. In the room DBX on the floor structure screen the top layer was specified at 1/4". However, the floor finish (K) was set to 0. THANK YOU! Link to comment Share on other sites More sharing options...
