mdavis0698 Posted January 31, 2019 Share Posted January 31, 2019 I need to see if there is a way to modify a monolithic slab. In this case I want to modify the vertical leg/foundation/footing. I began working in Architecture in 1978, and moved to Cad in the early 90's. I've designed and built many buildings using CAD (Various applications, but predominantly AutoCAD). In AutoCAD Architecture I was able to give the thickness of the slab, dimension of the chamfer from the slab to the vertical leg, the vertical leg height and thickness. I have not been able to discover a way to modify these settings in 2019 HD Pro, Is there something I am missing? Any help would be appreciated. I've modified the default settings (in every way I could find, and yes.... one at a time) for both the monolithic slab and the foundations. Link to comment Share on other sites More sharing options...
mdavis0698 Posted January 31, 2019 Author Share Posted January 31, 2019 Eric, that is a spread footing & stem wall. I'm talking about a monolithic slab, which is basically a concrete slab with thickened edges for a footing. In most places (such as where I am from), these are usually only used in commercial structures. However, Oklahoma has predominantly patio homes (on monolithic slabs). Link to comment Share on other sites More sharing options...
