LaraYoungDesign 0 Posted January 30, 2019 Hi sorry if this is a basic question. I am drawing a plan with exterior walls, but only have the interior dimensions of it. See image attached. I want the exterior dims to connect to the interior points. please help. TIA!! Share this post Link to post Share on other sites
solver 630 Posted January 30, 2019 Answers often depend on which title (Suite, Pro etc) and version (2018, 2019 etc) you are using. You can help everyone by adding this info to your signature (see below for how to turn them on, then see mine for an example) by clicking on your user name at the top right of the page, click Account Settings, then Signature on the left. Doing so makes it always available, and keeps others from having to hunt for it. And, turn on signature display too. ---- Resources for self help: The built in Help System (always a good place to start) Getting Started Knowledge Base YouTube Share this post Link to post Share on other sites
solver 630 Posted January 30, 2019 23 minutes ago, LaraYoungDesign said: I want the exterior dims to connect to the interior points. I don't understand. If you have interior dimensions, then use them to draw the walls, not exterior dimensions. The typical way to do this is to turn off all Auto Dimensions and turn on Temporary Dimensions. There are some good hour long getting started videos on YouTube, and there is the tutorial -- look under the Help menu. Share this post Link to post Share on other sites
