meowsqueak Posted October 29, 2014 Share Posted October 29, 2014 I built a cradle for an acrylic bathtub with four half-height walls. I placed this into a room, but the half-height walls appear to affect the ceiling (with moldings removed) and ceiling moldings: Holes in the ceiling (shown as blue) that seem to align with the two far half-walls of the cradle: Molding follows the holes, instead of the room walls: Is there a way to prevent these half-height walls from affecting the ceiling? If not, is there a better way to build a bath cradle? I'm using Home Designer Suite 2015, build 16.4.1.20OSX. Link to comment Share on other sites More sharing options...
katalyst777 Posted October 29, 2014 Share Posted October 29, 2014 is there a better way to build a bath cradle? Yes, use cabinets instead of half walls. http://www.homedesignersoftware.com/support/article/KB-02020/ 1 Link to comment Share on other sites More sharing options...
Solution meowsqueak Posted October 29, 2014 Author Solution Share Posted October 29, 2014 Yes, use cabinets instead of half walls. http://www.homedesignersoftware.com/support/article/KB-02020/ Thanks, that looks promising - I'll give it a try. EDIT: that worked very well, thank you. P.S. the reason I used half-walls is due to this article: http://www.homedesignersoftware.com/support/article/KB-00886/ Link to comment Share on other sites More sharing options...
Kbird1 Posted October 30, 2014 Share Posted October 30, 2014 Did you try setting the 1/2 walls to no locate , and/or no room definition ? M. Link to comment Share on other sites More sharing options...
meowsqueak Posted October 30, 2014 Author Share Posted October 30, 2014 Did you try setting the 1/2 walls to no locate , and/or no room definition ? M. Yes, I did try that both of those but it had no effect on the ceiling result. I think it is because the half-walls are parallel to and very close to the main walls. They don't cause a problem when they are perpendicular, or some distance away from the main walls. Link to comment Share on other sites More sharing options...
Kbird1 Posted October 30, 2014 Share Posted October 30, 2014 okay thx for followup , I was thinking the half walls spaced against the exterior walls ,was generating a room (definition) somehow and thus you automatically got the mouldings. Link to comment Share on other sites More sharing options...
