Temporary dimensions not appearing
447Debbie
Update:  Figured it out once I figured out they were called temporary dimensions.  I still don't know how it got turned off.  To turn back on go to View - Temporary Dimensions
Just minutes ago I was able to click on a wall, and Home Designer Pro 2019 would display the temporary dimension from that wall to the next wall, or from one object to another object.  All of a sudden I no longer get that dimension display.  I'm not talking about the interior or exterior dimensions that end up "permanent" on the drawing, just the one that would display while the wall was selected.  This must not be plan specific, because I've opened older plans and it has also disappeared from those. What did I turn off?
