BUILDERGREG 0 Posted December 1, 2018 My interior lines are now not straight and do not line up correctly vertically and horizontally. Also when i want to measure, the line doesn't run linear so the measurement does not calculate. I must have hit a wrong button somewhere. Any suggestions? Thanks. Share this post Link to post Share on other sites
solver 630 Posted December 1, 2018 Welcome BUILDERGREG. Answers often depend on which title (Suite, Pro etc) and version (2018, 2019 etc) you are using. You can help everyone by adding this info to your signature (see below for how to turn them on, then see mine for an example) by clicking on your user name at the top right of the page, click Account Settings, then Signature on the left. Doing so makes it always available, and keeps others from having to hunt for it. And, turn on signature display too. ---- Resources for self help: The built in Help System (always a good place to start) Getting Started Knowledge Base YouTube Share this post Link to post Share on other sites
solver 630 Posted December 1, 2018 I'll suggest you start with this video. Then begin with a new plan and practice drawing walls and using the dimension tools. Make sure you understand the settings that David showed in response to your other post. Also helpful for others to see what you see -- posting a screen capture or 2, and your plan file (close Home Designer first) will will help others help you. Watch on YouTube: https://www.youtube.com/watch?v=BqOuoZKrHpQ Share this post Link to post Share on other sites
