Lumber1 Posted July 23, 2018 Share Posted July 23, 2018 Hello! I'm running Home Designer Pro 2018 and have a question regarding a stud measurement in a wall (rake wall). If I select the stud in the floor plan view and open the object I get a length of 67". If I then open an elevation of the wall and highlight the stud, the system gives me a dimension of 67" as well but it appears the dimension is taken to the middle of the stud rather than the longest point. Is this just the way the dimension is displayed or is there a way to see what the length is to the longest point? The top of the stud is cut at a 45 degrees (12 in 12 pitch). Thanks Link to comment Share on other sites More sharing options...
