Stewart-design Posted June 4, 2018 Share Posted June 4, 2018 What is a good way to create an arch on top of a wall? I am trying to show a wall or railing in perspective and 3D that is arched on top and can be modified as needed. Any suggestions? Thank you, Link to comment Share on other sites More sharing options...
DavidJPotter Posted June 4, 2018 Share Posted June 4, 2018 First I need to know what software and its version you are using, that is liable to be the limiting factor for workable answers. I also need to know more exactly what your curved wall or railing needs to look like (a sketch or photo of a similar Architectural effect). DJP Link to comment Share on other sites More sharing options...
Stewart-design Posted June 4, 2018 Author Share Posted June 4, 2018 I am using Home Designer Pro 2018. The attached file and elevation drawing should communicate what I am trying to accomplish. The arched CAD polyline on the elevation drawing is about the arch size I need for the wall it is against. Thank you for your help. 1545 Napoli way arched wall.pdf 1545 Napoli way.plan Link to comment Share on other sites More sharing options...
DavidJPotter Posted June 5, 2018 Share Posted June 5, 2018 what you might do DJP Link to comment Share on other sites More sharing options...
