Sign in to follow this
Skydivewags
VR glasses how do you move?
I was excited to find out that I can view a model I designed with VR glasses, but from what I can see, you can't move around once you are in VR mode. The only thing I have been able to do is get my camera view lined up in the middle of the room, then switch to VR. At that point, the only thing I can do is turn in a circle, 360 degrees.
I am using a Google pixel XL with the Google daydream view.
Thanks for any help!
Mark
You have to make multiple cameras in your plan, and save each one before uploading your plan to your Chief Cloud account. You will know you have them saved because you can see them on your plan in Home designer.
Then when you put the 3d viewer in VR mode, look down at the menu circle below you, and it will let you select the Cameras you saved with your plan to your cloud.
