Starwolf Posted October 1, 2014 Share Posted October 1, 2014 I would like to import some 3d files from Turbocad 21 into my Home Designer Suite 2015 house.Has anyone done this with any of the Turbocad 3d designs they have made from this or earlier versions of Turbocad? Link to comment Share on other sites More sharing options...
Elovia Posted October 2, 2014 Share Posted October 2, 2014 Welcome to the forum. I'm not familiar with Turbocad, so my advice will be somewhat generic. When you're in your version of Turbocad (I see there are many, as well as a host of add in modules), see if you can locate or identify which 3D model types that software is capable of exporting. Then, open your Home Designer Suite software and see which types of 3D models it will import. The export -> import may not be flawless, as I'm sure 3D models native to Turbocad will look best within Turbocad, and there usually is some form of loss when converting to alternate 3D model standards. Good luck, and hope this helps. Link to comment Share on other sites More sharing options...
Kbird1 Posted October 2, 2014 Share Posted October 2, 2014 Elovia got it right , ,not familiar with Turbo Cad either but it may mean updating to HDA or Pro depending on what you can or can not import export. Link to comment Share on other sites More sharing options...
