HummingGardens Posted December 25, 2017 Share Posted December 25, 2017 I find difficulty to nail the mold on a wooden door. Can anyone suggest on how to do it perfectly. Because Each time I try it, The lines are not properly coordinated with the outlines.If else to go for a real estate agent or home repair, it would cost more. Link to comment Share on other sites More sharing options...
DavidJPotter Posted December 25, 2017 Share Posted December 25, 2017 Generally speaking, Home Designer software has little native ability to customize objects. You can look into downloading objects that better suit your purpose at 3D Warehouse (a large library of free objects made using Sketch Up, which can be downloaded and then imported into most Home Designer titles for placement in plans. You did not mention what software you have and use so I cannot be more specific than the above. Chief Architect Premier offers the most additional choices and tools for customizations like you are talking about but of course, it costs a lot more as well. All home designer titles, except HD Pro are for hobbyists and amateurs. Chief Premier is for Professional Use. DJP 1 Link to comment Share on other sites More sharing options...
