blackbeard Posted November 24, 2017 Share Posted November 24, 2017 I am having knee wall issues. I have drawn a basic cape code, two rear manually drawn dormers, two bedrooms, hall, and a bath. See attached image. When I push out the bathroom wall into the attic space, the roof decides to push up which it should not do. My roof is 12 in 12; the finished floor height is 95 5/8". All east/west walls are set to knee wall. Each room structure is set to ceiling over space. I didn't have this problem with 2014 edition. Any suggestions? (Hopefully a solution will also fix the wall-less dormers on 3D view.) Kevin Kilpatrick HDA 2017 Link to comment Share on other sites More sharing options...
blackbeard Posted November 25, 2017 Author Share Posted November 25, 2017 Thank you very much. Turning off the auto rebuild worked. Kevin Link to comment Share on other sites More sharing options...
