HDbyJustin Posted October 25, 2017 Share Posted October 25, 2017 Is there a way to check the scale of the view you sent to layout? Since C size is the largest sheet I end up having to use 3/16" for floor plans, most of the time! Sometimes I forget what scale I sent a plan or elevation to layout. I also wanted to ask if the text heights are adjusted when you send something to layout. Typically I run a 3/32" print height for all of my plans/elevations. The default is 1/8" and shows for 1/4"=1'-0" in the text format dialog, My text always looks bigger than it should be so it leads me to think its not adjusting my text based on what scale I used when I sent to layout. I don't have a plotter at home so i don't have a good way to put my scale on it. Link to comment Share on other sites More sharing options...
