HowieB Posted October 11, 2017 Share Posted October 11, 2017 I have a problem experimenting with a skylight / lantern window. The idea is almost that from inside it feels like a lantern window but from the outside there is just a part of the roof line which is glass. Because a skylight cannot be angled, I put in two skylights next to each other. The trouble is that I am then automatically given a kind of 'divider wall/ceiling' as per the image, which I am not going to want. Would be grateful for advice. Link to comment Share on other sites More sharing options...
HowieB Posted October 11, 2017 Author Share Posted October 11, 2017 Hi Build is 19.3.1.8OSX and it is Professional Trial Version (I am taking time to try and get familiar prior to renting or buying) 15 Sept 2017 Running on Mac (will add to signature) It doesn't seem to behave like a wall at all. To 'select' it one has to select the Skylight object. But there is nothing in the Skylight object menu that gives me control over this divider. In reality I would want a number of panes of glass there anyway. eg 3 each side. But at this rate I'd end up with a honeycomb... Other windows are only vertical Link to comment Share on other sites More sharing options...
