neo2222 Posted September 18, 2014 Share Posted September 18, 2014 Can anyone tell me how I would make knee bracing for support on deck support posts. This is required by code, so I'd like to put it in the model. Link to comment Share on other sites More sharing options...
Evolution Posted September 18, 2014 Share Posted September 18, 2014 Some of the answer you request will require the forum members to know what version of soft ware you are using. I am not sure based on that answer if there is anything you can use in the library, but you probably could use a shape, custom slab, other CAD drawing tools; etc., to achieve what you show in the attached details. Link to comment Share on other sites More sharing options...
Kbird1 Posted September 19, 2014 Share Posted September 19, 2014 A sloped Soffit may work , with the wood of choice material applied , then use copy/paste to make more of them... M. Link to comment Share on other sites More sharing options...
