Sign in to follow this
sk3499
How do I remove a floor in HDPro?
Hello,
I have a second level room (most of the house) that I want to remove the floor of. How do I tell Home Designer Pro to make the floor go away? I want it to be vaulted ceiling.
(When I say floor go away I mean the actual floor... not the level of the house.)
Thanks
You ask about Pro, but your signature says Suite -- which is it?
What specifically do you want to remove? The Finish Floor, the Floor Structure?
Like Chopsaw said, you can use the Open Below room type to remove everything, or just adjust other settings to remove individual items.
And it depends on what title you are using.
I didn't realise it said suite 14. I have  Pro 15 now. not sure how to change it.
I found the room type: open below... that worked. Thanks
Click on your user name at the top right of the page, click Account Settings, then Signature on the left.
