LeilaLaskujarvi Posted June 7, 2017 Share Posted June 7, 2017 I would like to create Architectural Blocks but I have no idea where the Create Architectural Blocks button located. Can anyone let me know? Their info page doesn't say where it is. I use Home Designer Architectural 2017. Thanks, Leila Link to comment Share on other sites More sharing options...
crosscutter55 Posted June 7, 2017 Share Posted June 7, 2017 i have had issues finding also !!! i have seen it pop up though lol !!! I believe it shows up in certain views Try searching architectural blocks in the search area @ the top of the screen under your user name .Also fill out your signature card PLEASE IT HELPS SO MUCH TO KNOW WHAT VERSION & PROGRAM YOU ARE USING .Click on your name go to account settings , on the left side of the screen click on signature . you will see another window like an e mail type your info in there Link to comment Share on other sites More sharing options...
crosscutter55 Posted June 7, 2017 Share Posted June 7, 2017 I found it When you want to create a block for some items hold the shift key down & drag a square ( MARQUE ) around those items , You should see the aritectural block icon ( blue & red BOX ) in the bottom edit tool bar . Link to comment Share on other sites More sharing options...
LeilaLaskujarvi Posted June 8, 2017 Author Share Posted June 8, 2017 Thanks for your help! Link to comment Share on other sites More sharing options...
