line weights in vector and technical views
Douglas49
Hi
I appear to be missing something re setting up lines weights, especially for vector, technical and elevation views,
The default settings I have bring up quite a heavy line whereas the ideal is a much finer line. I've seen this in HD and CA videos so I understand it can be done.
I see one can change the line weights in the layer display options, but which ones do I change and to what setting for these views?
I've read up on it in HD help, but can't spot the solution.
I have attached an example to try and communicate what I'm saying - how does one reduce the line weight to a nice fine line?
Regards
Doug
HD Elevation.pdf
HD Technical Illustration.pdf
