Architectural 2018 Roofing issues when upgrading plans from 2017 - issue 2
briancaos
This is just a follow-up from this previous post
It seems that Architectural 2018 have roofing issues as this house also have a roofing defect, again I suspect the "High Shed/Gable Wall" to be the cause of the issue. When removing all "High Shed/Gable Wall"'s, the roof falls back to it's normal (obviously without the cool high shed wall effect).
If this a bug, or does anyone know how to fix the issue?
Attahced is a .zip file containing the plan file.
CoeurDAlene_-_Riverstone_-_5.zip
Brian, I think I found a workaround.  If you can open the plan with the 2017 program, open the build roof specification and UNCHECK auto roof.  Save the plan with a new name.  I successfully opened the newly saved plan and the roofs looked right in 2018.
Hopefully this will work for you in Architectural as well.
CoeurDAlene_-_Riverstone_rebuild_off_2018-_5.zip
