reke12 Posted March 30, 2017 Share Posted March 30, 2017 Hello - can't seem to get this right. Using rainbow tool to change the size of Limestone tile from library to 12" x 24". Tried changing size both in General and Texture (Scale) tabs and no change in camera view but if I check stretch to fit I get what looks like a 12"x24" tile but layed out at weird overlapping angles in places. Help would be greatly appreciated. Using Home Designer Pro 2018. Thank you! Link to comment Share on other sites More sharing options...
Northriver Posted April 3, 2017 Share Posted April 3, 2017 Make sure you did not have the "paint roller" Icon selected when spraying the new material over the old or it will blend the old with the new. Your defaults will not change also when spraying one material over another. Link to comment Share on other sites More sharing options...
