Mulled Transom
RASmith
I am using home designer pro 2017 and my design has mulled double hung windows. Now I am trying to add transoms to some of them and it will not mull the transom to the windows. Any ideas would be great.
1) Please fill out your Signature -- see below.
2)
The Home Designer products do not have a Mull Windows tool (command).
You may push two or more windows together side to side and the look is OK. The issue is when you are stacking windows.
You might try removing the casings, and on the upper window, the sill and apron.
Use a Material Region (Custom Backsplash in Pro) as your casing.
It helps if we know what title (Suite, Pro etc) and version (2014, 2015 etc) you are using. You can add this info to your signature by clicking on your user name at the top right of the page, click Account Settings, then Signature on the left. Doing so makes it always available, and this info is often key to providing a good suggestion
Resources for self help:
